Sign in to my account
Don't have an account?
Create an account
Menu
Be prepared with disaster recovery on Google Cloud
It has never been easier to protect your data on Google Cloud. NetApp® Cloud Volumes ONTAP® software delivers cloud-based disaster recovery (DR) with highly efficient data replication, built-in storage efficiencies, and simple DR testing. Unify data management across your on-premises and Google Cloud environments with intuitive, drag-and-drop simplicity. Cloud Volumes ONTAP provides cost-effective and secure protection against errors or disasters.
Build a cloud-based disaster recovery environment
Disasters happen. Whether they’re due to power outages or hardware failures, you have to be prepared for anything that might disrupt operations. Increase business resilience with storage tiering, data replication technology, and space-efficient DR testing. With Google Cloud and Cloud Volumes ONTAP, you can cost-effectively protect your data and maintain operations when physical infrastructure has been compromised.
Agility
Create a DR replication in Google Cloud
Security
Data is encrypted in transit and at rest
Cost savings
Get TCO as low as $0.01 per GB per month
Low risk
Capture cloud benefits without migrating data
The ONTAP function that can be used with Cloud Volumes ONTAP gives you a great sense of security. I sense the high reliability that has been forged in a mission-critical environment.
Yoshinori Yokoyama-san, System 2nd Group Leader, Systems Department, Polygon Pictures
NetApp technology, such as Cloud Volumes ONTAP, is the right fit for dentsu because it allows us to accelerate our cloud transformation, while delivering significant savings to the business.
John Howarth, Head of Infrastructure Transformation, dentsu
Cloud Volumes ONTAP
Are you ready to optimize your cloud storage costs and performance while enhancing data protection, security, and compliance?
Drift chat loading
