One of the most consequential IT projects you can undertake today is to digitally transform your approach to data center management. But a digital transformation can be tricky to pull off. Not only do you need to know where your current approach falls short, you also have to understand what it takes to adopt a better one.
So how do you do it? By starting out with a bit of unbiased feedback from your peers. That’s why we launched this new blog series highlighting reviews by verified customers of ours on IT Central Station.
Join us as we look at how one customer saved significant time and money by using validated designs for the FlexPod® data center solution from NetApp and Cisco.
...it's better to go with something that has been vetted, tested, and designed by people with knowledge, as opposed to trying to go on your own. This is why we chose a certified, validated design.According to the reviewer, the scalability and stability that FlexPod brought to Long View Systems have also been incredibly valuable.
In addition, the reviewer has been able to reduce deployment time.
The scalability is one of the key features in this solution.
Adam Fore is Senior Director of Portfolio Marketing at NetApp. A 20-year veteran of Product Management and Product Marketing in the high tech industry, Adam has spent the last years at NetApp and currently manages solutions that span the NetApp portfolio including the FlexPod data center platform.
